Wish you could warm up or cool down your Nissan NV van before you even step outside? This Start-X Remote Starter Kit lets you do just that—if your van doesn't have an immobilizer system (super important: check that your dash doesn't show a flashing car/key symbol when off). It's designed specifically for 2012-2021 NV1500, NV2500, and NV3500 models. The best part? It's a true plug-and-play setup. The custom T-harness connects right into your factory wiring at the BCM, so there's NO cutting or splicing wires. Installation is cleaner and way less intimidating. To start your van remotely, just press the lock button on your factory key fob three times. It's that simple. Great for cold mornings, hot afternoons, or just adding a bit of modern convenience to your workhorse vehicle. Includes support from Start-X if you need help. Make your drives more comfortable from the get-go!
